Warum hat IMASAT die Daten jetzt erst rausgegegebn bzw rausgefunden das die Boing noch was gesendet hat?
lt. Homepagemitteileung v. 14.03.14 von Immarsat wurden die Daten an den Partner SITA weitergeleitet, bzw. mitgeteilt, dann sollte die Frage warum der Informationsfluss zwischen SITA und malaysischer Regierung schlecht war dort zu suchen sein.
Statement Immarsat (Zitat:)
"Routine, automated signals were registered on the Inmarsat network from Malaysia Airlines flight MH370 during its flight from Kuala Lumpur.
This information was provided to our partner SITA, which in turn has shared it with Malaysia Airlines.
For further information, please contact Malaysia Airlines."
http://www.inmarsat.com/news/inmarsat-s ... ght-mh370/
Die hätten das theoretisch vlt. auch früher weiterleiten können, aber anscheindend haben die eine neue Merthode angewand, die aufwendiger war, dies nachzuvollziehen
Statment malaysischer Premierminister:(Zitat:)
"In a press statement this afternoon, Prime Minister Najib Razak said that, using a type of analysis "never before used in an investigation of this sort", Inmarsat engineers have been able to establish that the plane's last position was in the middle of the Indian Ocean, west of Perth
"This is a remote location, far from any possible landing sites. It is therefore with deep sadness and regret that I must inform you that, according to this new data, flight MH370 ended in the southern Indian Ocean."
Inmarsat’s role in the search for Malaysian Airlines flight MH370 began immediately after the aircraft disappeared. Although the main aircraft communications addressing and reporting system (which would usually transmit the plane's position) was switched off, one of Inmarsat’s satellites continued to pick up a series of automated hourly 'pings' from a terminal on the plane, which would normally be used to synchronise timing information"
http://www.telegraph.co.uk/technology/n ... MH370.html
Warum sucht man Tagelang erst an der falschen Stelle?
wahrscheinlich Strömungen und Winde, die Ecke ist anscheinend bekannt dafür
wegen des Leserkommentars; überwacht Echelon auch Flugzeuge und Flugrouten? weis ich nicht..
bei den U-booten weis man ja nicht ob da grad welche auf Fahrt waren oder so. Ich weis auch nicht wie die Reichweite die Sonare haben. Aber wenn die Blackbox z.B. in irgendwelchen Seegräben liegt könnte eine Ortung über Sonar mit einem normalen U-boot schwierig werden, die können nur einige 100m tief tauchen, evtl. reicht dann eine Sonar gar nicht bis unten (wenns Meer da 2000-5000m oder so tief ist ist die in ner oder Felsspalten etc. liegt).
Hoffe allerdings dass sie die Blackbox noch finden, die Auflösung des Ganzen wäre schon schön..
PS: aber warum halten die Akkus der Blackbox eig nur 4 Wochen? sollte doch kein Problem sein, da haltbarere rein zu tun? und auch net arg teurer?
