307 Breaknck
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Mo 29.08.11 22:47
Time to move on to happier updates, I think! Haha.
It's time to revisit and finally complete the audio system, starting with a messy job of properly
installing the front speakers at long last! Typical French - holes everywhere in the door, except
where I need one to be.
Inner skin was cut-out and prepared to take a custom MDF speaker pod. With the pod in place
and firmly attached to the door's inner skin, we treated outer skins, pods and door cards treated
with a couple of coats of bitumen, for at least some vibration damping.
And finally, speaker installed and all the holes sealed. What an unbelievable improvement of
my audio system, quite possibly the biggest single upgrade I've done so far!
Door cards back on, though I did have to remove the lower hole cover I had made, so I will
have to revisit it later and also add LOADS of Dynamat or such material everywhere in the doors.
The next update will be all about audio as well :).
Photos here: http://photos.cybernck.com/307breaknck?page=10
Quicksilver307
Postleitzahl: 99510
Re: 307 Breaknck
Beitrag von Quicksilver307 » Di 30.08.11 21:38
Good work... :daumenhoch:
Bild Bild Bild
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Sa 10.09.11 02:01
Time to finally complete my envisaged audio system!
Out with the old 4-channel amplifier (Magnat Rave 440, on the left, good little amp), in with
the new one (Focal FP 4.75, on the right). Specs: 4 x 75W @ 4 ohms, 4 x 100W @ 2 ohms,
2 x 200W @ 4 ohms. Full active crossover and an output for a second amp.
Previous configuration was 2+1 ch, but since I'm going to run front Focal 165K2P speakers
on Focal FP 4.75 in bridged mode with low gain, it's accompanied by it's monoblock brother,
Focal FP 1.800 (with remote gain control) for the subwoofer.
Specs: 1 x 400W @ 4 ohms, 1 x 600W @ 2 ohms, 1 x 800W @ 1 ohm. Focal 33KX beast
will be unleashed :-).
Additional wiring was required for the additional amp.
With the front speakers properly installed and with the addition of new amplifiers, I am very
happy with my audio system now! I keep hearing details I previously haven't, in the same
tracks and songs. Next mods will be sound deadening and a better headunit.
As you can see, the 18" RS GT wheels are back on the car as well :).
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Mi 05.10.11 00:28
With the audio install finished at long last, it was time to turn my attention to exterior and
fit parts I've had laying around for quite some time, but the first job was to get the bodywork
cleaner and shinier by a professional polisher.
Then came a long awaited solution to a "radio controlled car" antenna, in form of a short
OE antenna, part number 6561.QQ, found on various models (607, 807 etc). Fits nicely
and radio reception seems fine, but I don't listen to radio at all, so it doesn't matter to
me either way :).
Someone had stolen my rear wiper blade a long time ago and the wiper arm (6429.T8)
had a lot of play in it, so I bought both parts new. The wiper arm required a bit of persuasion
from an angle grinder to come off though.
As I decided to update the tails lamps to Phase 2, I went for Phase 2 side indicators as well.
6325.G3 - 206 Phase 2 side indicators (x2). Exactly the same as 307 items (6325.G4) but at
half a price. Go figure. Not too visible in daytime, as the bulb is hidden.
Phase 2 tail lamps! Compared to Phase 1 lights, they look much brighter, fresher and more red,
thought with a bit of a "China" look and feel to them. They fit the car straight on, but you need
additional two 5W bulbs, compared to Phase 1 lights.
Exterior mods completed. Not much of a photo, but shows how shiny the car is.
That's it for the bodywork mods, for the time being anyway.
Photos here: http://photos.cybernck.com/307breaknck?page=11
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Sa 21.01.12 21:18
Here's a small but sweet update :).
The almighty 6554F4 ESP OFF switch :-). Don't know what the price is, as I got it
as a part of a 307 CC center console.
I really can't understand the logic of having all the wiring installed, as well as the feature
implemented, but deciding to blank it off instead of fitting a switch! :-/ The new button
fits straight in.
Et voila! I can now turn off the ESP and traction control off, which is required sometimes
when the ECU can't figure out what's the best thing to do.
Full-size photos here: http://photos.cybernck.com/307breaknck?page=11
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Mi 10.10.12 00:02
With my cycle racing season finally over, I'm going ahead with my little project, finally mounting
some parts I've had laying around for nearly a couple of years now. Here you can see 307 Automatic
alloy pedal set I got off eBay, a genuine 307 CC leather steering wheel form a UK breaker's yard
and finally, some genuine 307 alloy front sill plates, part number 9623.76, also an eBay special.
Bild Bild Bild
Mounting the brake pedal using supplied allen screws is straightforward after removal of the original
rubber pedal cover, as the holes for the screws are already there. However, throttle pedal was a bit
of a challenge and had to be removed because of the construction of the pedal.
It would have been nearly impossible to position it right while at the same time manage to bolt it up,
so we riveted it on instead. The removable leg rest offers easy mounting of the leg rest pedal.
We opted for riveting on this one as well.
Next up, the steering wheel. After disconnecting the battery, airbag is easily removed using two
flat-headed screwdrivers inserted in the holes at the back of the steering wheel. A word of warning -
do not fully unscrew and remove the main torx bolt until you've managed to release the steering wheel
from the steering crown, as you'll probably end up tearing off all the airbag connectors!
Fitting the other wheel is a reverse of the removal. And there are no spare bolts left, for a change! :-)
And finally, fitting the sill plates is super-easy and quick, as it comes with a self-adhesive tape
on the back. You just need to lift the plastic cover and rubber seal off of the sill seam, clean up
and degrease the surface, test-fit the sill plate and and then stick it on. Job done!
I will continue with this "307 CC interior upgrade pack" in the next update too :).
Full size photos available here: http://photos.cybernck.com/307breaknck?page=12
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Fr 26.10.12 14:44
Next up - 307 CC white clocks with chrome rings, red needles and radial writing. Got them from the UK
(eBay once again), so they're in mph but they also have a km/h scale, in small print.
It was not a simple plug'n'play affair though, because I needed to keep my circuit board. Therefore,
armed with a Torx bit, I started disassembling them to bits. I even had to go the lengths of cutting out
and swapping the center "display" part, so the warning lights would remain correct.
Bild Bild Bild
Et voila! Clocks finished, fitted back into the car and looking classy, in my opinion.
And finally - a "before and after" shot, to sum it all up. The new details really smarten up the interior
and the steering wheel is much nicer to use.
As far as interior mods are concerned, that's it for now, but I've definitely got another thing or two planned ;-).
madmadix
Rettungswagenüberholer
Postleitzahl: 35114
Re: 307 Breaknck
Beitrag von madmadix » Fr 26.10.12 20:35
haj,
thumbs up! :daumenhoch:
good work! :)
Peter
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Mo 05.11.12 19:53
My exhaust had developed a booming noise and eventually the pipe going into the backbox broke off,
so I took it over to an exhaust service place for a fix.
While at it, I took an opportunity to remove the broken spare wheel mechanism to finally check
what's going on with it. The problem was quite obvious and it's a common one on 307 Break & SW cars.
The solution was simple - new cable made based on the original one - much cheaper than a complete
new mechanism from Peugeot.
Bild Bild Bild
Fitting it back on isn't such a simple job when you're doing it in a car park but the spare wheel
will finally be gone from the boot and back under the car!
Bild Bild Bild
Meanwhile, my expensive Varta battery had died (just outside the warranty period - typical).
I purchased a cheaper 60Ah one this time, that seems to do the job just as well.
Full size photos available here: http://photos.cybernck.com/307breaknck?page=13
cybernck
Re: 307 Breaknck
Beitrag von cybernck » Mi 26.12.12 23:27
Just a quick update.
I've had this idea for winter wheels setup for a while and I've finally got it done now.
406 Coupe V6 Starfish wheels, 7x16" ET12. I don't think I've ever seen another 307
with them on.
Bild Bild
Nice and wide, they fill the arches just like the later version Coupe wheels (Hoggar)
I've had on the car in the past, but visually suit the 307 better. All I now need is
a V6 engine, haha.
