With my cycle racing season finally over, I'm going ahead with my little project, finally mounting
some parts I've had laying around for nearly a couple of years now. Here you can see 307 Automatic
alloy pedal set I got off eBay, a genuine 307 CC leather steering wheel form a UK breaker's yard
and finally, some genuine 307 alloy front sill plates, part number 9623.76, also an eBay special.
Mounting the brake pedal using supplied allen screws is straightforward after removal of the original
rubber pedal cover, as the holes for the screws are already there. However, throttle pedal was a bit
of a challenge and had to be removed because of the construction of the pedal.
It would have been nearly impossible to position it right while at the same time manage to bolt it up,
so we riveted it on instead. The removable leg rest offers easy mounting of the leg rest pedal.
We opted for riveting on this one as well.
Next up, the steering wheel. After disconnecting the battery, airbag is easily removed using two
flat-headed screwdrivers inserted in the holes at the back of the steering wheel. A word of warning -
do not fully unscrew and remove the main torx bolt until you've managed to release the steering wheel
from the steering crown, as you'll probably end up tearing off all the airbag connectors!
Fitting the other wheel is a reverse of the removal. And there are no spare bolts left, for a change! :-)
And finally, fitting the sill plates is super-easy and quick, as it comes with a self-adhesive tape
on the back. You just need to lift the plastic cover and rubber seal off of the sill seam, clean up
and degrease the surface, test-fit the sill plate and and then stick it on. Job done!
I will continue with this "307 CC interior upgrade pack" in the next update too
Full size photos available here: http://photos.cybernck.com/307breaknck?page=12
